I can´t load any Script into Rhino 6, a messege shows…“Unknown command: _LoadScript”. I need help.
Sorry, my english is too bad.
Hello - please try a right-click and choose ‘Load plug-in’ if that is available -
Any luck?
Hello - can you please run Help menu > System information and paste the results here?
Looks like you have the wrong version of the RhinoScript plug-in loaded (4.0.something).
You should drag&drop the RhinoScript.rhp from the Rhino 6 installation folder onto a running v6 to fix.
I might try updating to the latest service release and see if that doesn’t fix the problem…
The one from C:\Program Files\Rhino 6\Plug-ins failed? You may want to update to the latest SR.
Are you running anti-virus software? I believe that the RhinoScript plug-in sometimes is improperly flagged. This may be the case in this situation.
Click the Check Now... link.
when i press the check now… nothing happens
I red another chat, and pascal said…“Probably the quickest way out is simply to download the latest and Uninstall/Install and see if that sorts it out.”
I will try
Done!!!
it works perfect
thank to you all
make my week
Saludos totales
