Hi there. I’ve recently been using Rhino for the past year and this year once I download Rhino it wont seem to load the app. Are you able to help me out at all. I tried looking at a thread where it said to change the graphics on the display settings and I’m not too sure where to go from here.
Hi @102519692
First thing to do, is to see if Rhino will run in Safe Mode. Go to the Windows Start button and look/search for Rhino 6/7 in Safe Mode. If Rhino succesfully starts, type the command SystemInfo in Rhino and copy/paste the resulting text here - that will give us an idea of what might be going on.
HTH, Jakob
Rhino 7 SR4 2021-3-8 (Rhino 7, 7.4.21067.13001, Git hash:master @ ed629035202f07e8b84a3ee211479ca20bb81b73)
License type: Evaluation, build 2021-03-08
License details: Cloud Zoo
Expires on: 2021-06-01
Windows 10.0.19041 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Unplugged [60% battery remaining] ~53 minutes left
Primary display: Intel® HD Graphics 630 (Intel) Memory: 1GB, Driver date: 7-24-2017 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1050 (NVidia) Memory: 4GB, Driver date: 9-1-2017 (M-D-Y). OpenGL Ver: 4.5.0 NVIDIA 385.54
> Integrated accelerated graphics device (shares primary device ports)
Secondary graphics devices.
Citrix Indirect Display Adapter (Citrix Systems Inc.) Memory: 0MB, Driver date: 1-23-2019 (M-D-Y).
> External USB display device with 8 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.5
Shading Language: 4.50 NVIDIA
Driver Date: 9-1-2017
Driver Version: 22.21.13.8554
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.4.21067.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.4.21067.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.4.21067.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.4.21067.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.4.21067.13001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
Hi Jakob.
Every time I click on Rhino and click “repair” my computer will re-start and run Rhino. Otherwise it still wont run in safemode.
Kind regards,
Sarah
Hi @102519692
Both your graphics drivers are 3½ years old, which is a lot in terms of graphics drivers. If you upgrade them, there’s a good chance that your system should work. Both Intel and Nvidia have much more recent drivers. In general, you should probably check for updates every 3-4 months as a minimum. Also here’s link to @theoutside’s brilliant write-up on what to beware of with hybrid graphics systems: Soooo, you bought a laptop with hybrid graphics and rhino doesn't run right. READ THIS
Cheers, Jakob
Edit: Here are links for both drivers
