Rhino doesnt start on windows - need help please
my hardware asus pro art laptop with rtx a3000 ada
latest windows update 2xH something
latest grafik card driver
few days ago i needed to do some work via rhino - the welcome window just disapears after trying to load plug ins. i was trying to follow which plugins these are, still didnt work
made a fresh installation, for removing rhino i used revo uninstaller pro… no additional plug ins, out of the box - rhino keeps crashing on welcome screen presumably loading plug ins…
does anybody have suggestions, workarounds, expirience with same/similar situation? i wouldnt know where to start like if there is any way to look into logs without having the possibility to actually start rhino…
thanks in advacne!! best regards, konstantin
starting in safe mode i get a message PlugInLaden couldnt be resolved during loading a plug in(kann nicht geladen werden, während ein Plug in geladen wird)),
Hi Kostyantyn -
Have you tried repairing the Rhino installation from the Windows Control Panel?
just did that - unfortunatly it didnt help:-( was hoping it could be an easy one…
Any errors?
When opening in safe mode it will ask you to load the default plug-ins, say yes then run SystemInfo and post the results. Thanks
the first message, when i start rhino in safe mode, i did post above already. then i get asked if i would want to load the Calc.rhp
SystemInfo:
Rhino 8 SR29 2026-3-4 (Rhino 8, 8.29.26063.11001, Git hash:master @ bbd126f84fcdaf7a974615b7c9f4f8667571c147)
License type: Commercial, Build 2026-03-04
License details: Stand-Alone
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 64GB)
.NET 8.0.25
Computer platform: LAPTOP - Plugged in [81% battery remaining]
Primary display and OpenGL: Intel(R) UHD Graphics (Intel) Memory: 2GB, Driver date: 6-21-2025 (M-D-Y). OpenGL Ver: (null)
Integrated graphics device with 4 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
Secondary graphics devices.
NVIDIA RTX 3000 Ada Generation Laptop GPU (NVidia) Memory: 7GB, Driver date: 3-17-2026 (M-D-Y).
Integrated accelerated graphics device with 4 adapter port(s)
  • Secondary monitor is laptop’s integrated screen or built-in port
ATTENTION:
Safe Mode is enabled. Graphics device usage and OpenGL information cannot be collected.
OpenGL Settings
Safe mode: On
GPU Tessellation is: On (but disabled due to other settings)
Graphics level being used: OpenGL (null) (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Unknown
Render version: (null)
Shading Language: (null)
Driver Date: 3-17-2026
Driver Version: 32.0.15.9597
Maximum Texture size: n/a
Z-Buffer depth: n/a
Maximum Viewport size: 16777472 x 16777216
Total Video Memory: 7676 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Rechner”
Plugin warnings are what you are supposed to see when loading in safe mode.
SafeMode disables your graphics and non-essential plugins for troubleshooting.
Do you have any errors in your Windows Reliability Monitor?
yes i do indeed related to rhino. i hope it does work for you in german? if not let me know…
Quelle
Rhino 8
Zusammenfassung
Nicht mehr funktionsfähig
Datum
‎09.‎04.‎2026 10:47
Status
Nicht berichtet
Beschreibung
Pfad der fehlerhaften Anwendung: C:\Program Files\Rhino 8\System\Rhino.exe
Problemsignatur
Problemereignisame: APPCRASH
Anwendungsname: Rhino.exe
Anwendungsversion: 8.28.26041.11001
Anwendungszeitstempel: 698b86c8
Fehlermodulname: coreclr.dll
Fehlermodulversion: 8.0.2526.11203
Fehlermodulzeitstempel: 698da12b
Ausnahmecode: c0000005
Ausnahmeoffset: 00000000001d4536
Betriebsystemversion: 10.0.26100.2.0.0.256.48
Gebietsschema-ID: 1031
Zusatzinformation 1: 5718
Zusatzinformation 2: 5718851685391035fa7d29c38b4530b3
Zusatzinformation 3: 21c3
Zusatzinformation 4: 21c331c34dececa4bc0f3039fd5cdc3c
Dateien zur Beschreibung des Problems
WERInternalMetadata.xml
this indicates that it’s something to do with the .net
The repair option can done with the following:
  1. Go to Control Panel > Programs > Programs and Features.
  2. Right-click Microsoft Visual C++ Redistributable and choose Repair.
  • Microsoft Visual C++ 2015-2022 Redistributable (x86) ← do this first
  • Microsoft Visual C++ 2015-2022 Redistributable (x64) ← you might be prompted to reboot.
looks like that was it:-D started few time with different files just to be on safe side… amazing, thanks for the guidence and help!!
