Hi everyone,
Is it possible to change the length of the lines that represents the levels through RiR?
Regards!
Hi everyone,
Regards!
The principle way this is done is via a Scope Box, unfortunately Scope Boxes have limited Revit API exposure. You can set a views Scope Box via its parameters.
Wow, thanks for the info @Japhy ! I am sorry but I do not understand it 100%, do you mean set a new Scope Box element parameter for the levels created, setting a new Scope Box? Do you have an example of how to do that?
Thanks in advance
Here is an example of setting the scope box
Thanks again! I still do not understand how the concept works exactly… Are the level representation linked to the view where they are created?
When the representation of a level in a view changes it is updated in all the views in the model as well. Then which is the view I am suppose to change?
These are complex representations (2d/3d per view), for details on how this all works the Autodesk help and AUGI forums are great resources
https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-4E36EDA0-2F4E-4619-B568-AC758E8D9770
