I am following the documentation to set levels in Revit from the “Add Level” component in grasshopper. The levels appear in Revit but their heads and tails are not in the locations I would like them to be in the elevations.
Is there a way to set them in the correct location from grasshopper. Does this have to do with thte scope box? Is there any way to set the scope box from Revit? I was not able to find much documentation on the scopebox.
Thank you!
Greg
