Let's add items to our popup menu
This new approach is by no means an improvement over the previous method in V7. Sorry to complain, but the stupidity of the upgrade keeps smacking me in the face. Here’s the amount of effort it takes to add a single command to the pop up menu.
Screenshot 2024-02-26 at 12.06.01 PM
  1. Click on settings
  2. Click on Toolbars
  3. Scroll down list menus and click on Popup
  4. Click Add
  5. Click select Command (from list of existing command scripts)
  6. Click ‘next’
  7. Here you’ll find a choice of ‘default’ or ‘defaultmac’.
Don’t bother with the 2nd as there’s nothing to find.
  1. Use the search space to type in command name
  2. Next, there’s a RMB option to consider.
  3. Choose the way you want the button displayed.
  4. Click ‘Finish’ and bingo - there it is in the popup menu!!
Yippee!!!
Now start over for the next item you want to add . . . .
Well Done developers!
And
  1. Open the popup menu and drag it a bit to make sure it stays on the screen
  2. Cmd + LMB drag the toolbar button that has the command you want from an existing toolbar into the popup
  3. Done…
Doesn’t work for you?
Or
  2. Right click in a space somewhere in the toolbar and choose “New button”
  3. Either add the command and image you want via the dialog, or Click “Blank Button” and finish
  4. If you used the blank button option, Shift+Right click on the new blank button and choose “Edit”, fill in the command (or a custom script, etc.) and add an image or text…
  5. Done.
Much Better. Not stellar but better.
It would be better if one could delete several items in one actions as opposed to one by one.
As for adding tools - this is what I typically work with. It seems long but my physical memory makes selecting what’s wanted quick and easy. Plus, at least in V7, I can use the list of last used commands with the LMB.
Thanks for your help kind sir!
But, how can I arrange them?
Shift + LMB and drag them around inside the toolbar and drop them where you want.
To delete a button, just Shift + LMB drag it out of the toolbar into the Rhino window and release. You will get a “Do you want to delete…” message to confirm deletion.
Thanks Helvi,
I’ve noticed after dragging a tool into the pop up it’s no longer in the default collection. I’ve tried holding different key combos to drag a copy but I’m not getting it right. I notice the offset curve command exists in both menus so I thought perhaps restarting would fix it. No. I’m sorry to be asking, I’m embarrassed and put off with how difficult it is to set up my interface. I’ve not experienced anything more tedious and unintuitive with any app I’be used in the last 30 years.
Edit -
Never Mind!
Normally Shift + LMB and drag moves a button. Cmd (Ctrl in windows Rhino) + LMB makes a copy wherever you drag the button. When you hover over a button and hit Shift or Cmd, you should see tooltips lighting up to that effect.
The RMB actions are Shift + click to edit (to open the button editor) and Cmd + drag to “link” (I don’t recommend this). The tooltips also show this.
It’s just not what you’re used to. This is how Rhino for Windows has worked since 1.0. It’s fast, easy and works - just drag and drop - at least it did up to V7. There are still a number of bugs in V8 (also on the Windows side) that have yet to be resolved.
It’s not so easy really. For instance, I want to add duplicate face border but I can’t find the button wherever I’ve looked. If I enter the command - there’s no hint as to where the button actually resides. In V7 there was a searchable interface for all the commands - I don’t think there’s anything like it now.
It’s really a tedious and irritating process to set pop up.
Is there something better in Windows?
While in the command, hit the
button. The Help will open with that command. It will tell you in what toolbar the button is located.
All I get is the general help panel. Is there a ? button elsewhere?
EDIT
Shit - now it works on a restart. Thanks!
