Customize Pop Up Toolbar
I have the tool bar pop up as per the middle mouse click.
How do I add commands do this menu?
Hello- if you float it when it is open, you can copy buttons into it or add buttons as in any toolbar.
Could you please provide a step by step?
This info should probably help:
https://docs.mcneel.com/rhino/7/help/en-us/index.htm#toolbarsandmenus/customize_toolbars.htm%3FTocPath%3DCustomizing%2520the%2520interface|_____3
I recall @theoutside did a video about customizing your popup toolbar, It was a part of a larger tutorial but I couldn’t find it.
pop up your toolbar via mmb, then grab wiggle the light blue title bar at the top to “dock it”
Now simply ctrl+drag buttons to your bar to add to them.
(NOTE: do not shift+drag to add!! this moves the tool, you want ctrl+drag which copies the tool)
once you have the tools in your MMB pop up, you can THEN use shift+drag to arrange them, or pull them out to delete them.
If you try to use ctrl+shift to arrange, you’ll make copies of the buttons and that’s not what you want.
once you have them arranged, you can shift click to edit the underlying button code and even the icon if you so choose.
once you are done, hit the red x in teh upper right corner to close the docked mmb menu and then test by hitting you mmb again.
it should pop up with the correct buttons installed.
