Hi all,
I would like to found/create an algorithm to generate this kind of leaves patern with grasshopper with smaller and bigger pipe and tree structure inside.
If you have any idea or recources to start with it would be wonderfull !
Thank you in advance,
Have a good afternoon !
msajdek
(Msajdek)
December 4, 2023, 3:47pm
2
I’m not sure, but similar effects could potentially be achieved with the space colonization algorithm.
Hi. I’m keen to try to replicate this fabulous pattern with Grasshopper but have so far failed.
I’ve tried both working from the centre and ‘growing’ outwards with the spokes dividing at intervals, and also starting from an outer circle, dividing the curve and working inwards.
Perhaps a bit ambitious for me but any pointers/help would be most appreciated (I’m using Rhino 5).
[Upturned lily leaf]
Here is a Fruit Bowl I designed and make it printed by SandHelden
[IMG_8384]
[IMG_8388]
[IMG_8386]
[IMG_8389]
[image]
The bowl was designed using tools presented here
The curve network is first bend using a curve as profile. Then it is thickened using Dendro. A last tool is used to flatten the bottom in order to have a stable bowl, I added some plastic pads in order to not scratch wood (sand is quite abrasive).
I followed design guide provided by SandHelden, mainly minimum thickness mu…
And search for Venation on old grasshopper3d forum
dfytz1
December 4, 2023, 4:12pm
4
Thank you, Just found also this one that look really interesting :
Leaf venation using anemone - Grasshopper - McNeel Forum
dfytz1
December 4, 2023, 4:16pm
6
This attempt was not very successful
The best implementation so far is from Nervous System.
