Huge circular Victoria Amazonica lilly leaf pattern
Hi. I’m keen to try to replicate this fabulous pattern with Grasshopper but have so far failed.
I’ve tried both working from the centre and ‘growing’ outwards with the spokes dividing at intervals, and also starting from an outer circle, dividing the curve and working inwards.
Perhaps a bit ambitious for me but any pointers/help would be most appreciated (I’m using Rhino 5).
Search “leaf venation” on this forum… I think there have been some examples
I looked at that venation but thought it was rather different. With the lily the spokes seem to divide at more or less even radius, and then run out at an even parallel distance each time…
A bit similar
Some way with concentric circles
Hi Laurent,
Thank you, that looks great. Light years better than my attempts!
I’ll need some time now to figure out how your definitions work, and then add the ribs etc.
My goal is to try some cnc fabrication, not yet sure what with, laser cutter, mill, 3d printer…
Hi
here an awful script to do that
There are many logics it it.
First generate the pattern
The division of curves uses the equation here
but the equation is false
it is A(n) = 5 * 2 * n -2
The curve Network is smoothed (my equation) not sure it will stay long on this forum.
Upper part is used the make the ribs
Main logic is to extract inner parts, measure their lengths and cut them in quite equal lengths parts
The whole other part is using Dendro, transforming everything to points, moving points the make heights, putting good radius …
Great work Laurent
Hi Laurent,
That looks fabulous, exactly right. Thank you again.
I think the time has come when I’ll finally need to upgrade from Rhino 5 because I tried Pufferfish once before and it doesn’t like 5.
I think there’s a C+ component in there somewhere as well ldtils?
I can’t wait to try making one now!
Hei Laurent,
Is it the grasshopper definition still available?
I cannot find it anywhere.
Hello
the complete script is not available. You can recreate the script from what is published (less than 20 components). The only tricky part is to smooth the polylines, it is classical Catmull & Clark for polylines but I don’t know if there is an available script (I don’t give nor sell mine).
Chaikin’s algorithm?
2022-02-20 17-24-25.2022-02-20 17_25_43
Or cubic curve subdivision?
2022-02-23_21-18-17.2022-02-23_21_19_15
It is cubic curve subdivision, but it works with network of curves.
So it gives the skeleton of Fatten +Catmull-Clark Subdivision
This was way easier to implement than I first thought. :slight_smile:
cubic_subdiv
I used a directed graph to keep track of the lines. It’s cubic subdivision to smooth the line network, like in your example.
@diff-arch - check this thread where we were just talking about this topic again recently:
Hello
Cool you have done it. Did you test Chaikin way ? Yes it is quite simple so it is a bit strange it is not in a plugin. I have no the courage to make plugins for people that complains so much on free stuff.
I tested Chaikin on polylines, but not on line networks yet.
Preach.
The main differences between the two subdivision methods are that Chaikin’s algorithm (mauve) cuts corners and doesn’t shrink as much, whereas cubic subdivision (green) preserves a smoothed corner vertex and overall shrinks the curve a little.
chaikin_vs_cubic
Chaikin’s algorithm (2 levels):
Cubic subdivision (2 levels):
Now with face detection/recovery for planar, smoothed line graphs.
Hey Laurent! How did you divided the inner parts? Can you help me a bit? :slight_smile:
Thank you in advance
