Hello!
7.0.20266.15205
When toggling the layer visibility, the layer panel gets refreshed, which also leads to unwanted scrolling of the panel. Very annoying.
This does not happen in R6.
Thanks!
Hello - checking this, thanks.
@Eugen - I do not see this happening here - I may need more specific instructions ‘for dummies’
I added a lot of layers and scrolled the view toward the bottom - I had one layer highlighted. I toggled Layers off and back on and the same view was in the panel - the highlighted layer in the same location and view.
Hello!
Please check out this file
test layer panel.7z (9.9 MB)
where this happens. Could not repro it in a fresh scene.
Thanks!
Hi Eugen -
I wasn’t able to reproduce the behavior that you described with this file on 7.0.20271.2200.
I opened the file, then scrolled to the bottom of the layers list and clicked the lightbulb for the 2M_TSMS_P layer off and back on. There was no scrolling of the layer list.
Are you doing something differently or have any non-standard plug-in installed?
Hello! Thanks for looking into this!
My plugins are VisualArq, VRay, Enscape3d. Can this be related? Will try again later.
I’m getting the same thing on 7.0.20266.15205
I can’t share the file that’s causing it (700 layers and 460MB) but so far I can’t reproduce it in a new file. It seems to be intermittent even in the problem file, I’m trying to figure out the conditions that cause it.
-Grant
This problem is driving me absolutely nuts and it’s causing a lot of problems. I have attached a file where I imported a lot of geometry from a Rhino 5 file. It is an confidential document, hence I deleted all relevant geometries. The problem remains, Rhino scrolls / refreshes the layer panel automatically when clicking on the light bulb and lock. The layer where I click ends up being the lowest one visible.
Hi @martinsiegrist - if you disable all plug-ins that do not ship with Rhino, does this problem still occur?
– Dale
I disabled all these plug-ins (Evolute Tools PRO and Keyshot) and wasn’t able to repeat the problem. After that I enabled the plug-ins again and wasn’t able to repeat the problem. Weird. Then I thought it might be Elefront causing trouble via Grasshopper but again I can’t repeat the problem?
