Layer manager bug after latest update
After I updated my Rhino, the layer manager has problem when I want to assign another layer to an object.
When I click the ‘layer selector’ to open the list of layers, Rhino assigns the object instantly to the layer that is at this location where I clicked my left mouse button. In this case layer: 'Hull16GH (fair chine curves).
The only way to work around this is not to release the left mouse button and hoover over the other layers and then release my left mouse button.
See my system info below.
Rhino 8 SR20 2025-6-6 (Rhino 8, 8.20.25157.13001, Git hash:master @ 73b00899cf43922900a763212f167c03dc6f27cc)
License type: Not For Resale Lab, build 2025-06-06
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET Framework 4.8.9310.0
Primary display: Intel(R) HD Graphics 530 (Intel) Memory: 1GB, Driver date: 1-20-2022 (M-D-Y).
Primary OpenGL: NVIDIA Quadro M3000M (NVidia) Memory: 4GB, Driver date: 6-26-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.45
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-26-2023
Driver Version: 31.0.15.3645
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\ADA 3D\Mesh2Surface for Rhino 6\m2s_for_Rhino.rhp “MESH2SURFACE”
C:\Program Files\Orca3D V3\Orca3D.rhp “Orca3D” 3.1.4.0
C:\Program Files\Bongo 3.0 (64-bit)\Rhino8\Bongo.30.rhp “Bongo 3.0”
C:\Program Files\Scan&Solve Pro for Rhino 6 & 7\SnSPro_Rhino_6+7.rhp “Scan&Solve Pro for Rhino” 1.0.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.20.25157.13001
C:\Users\User\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.20.25157.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.20.25157.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.20.25157.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.20.25157.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.20.25157.13001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.20.25157.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.20.25157.13001
I’m not so sure it has anything to do with this problem, but I’m surprised you haven’t run into any other weirdness with video drivers as old as yours, considering how many people on the forum have had Rhio 8 problems go away by updating drivers newer than yours.
hehehe, I am very happy with my old laptop and have a new one for more than one year on standby.
Thank you for reading my post!
I wonder if this is related to
https://mcneel.myjetbrains.com/youtrack/issue/RH-87718/Changing-Layer-with-Statusbar-also-clicks-on-panel-behind
if you select an object and try to change its object, you also click on whatever is behind it?
Rhino_Click_Behind
Yeah! It looks like the same problem.
Although over here I cannot repeat your specific example of this problem.
I have had confirmation that this bug will be fixed in the next Service Release :smiley:
