Rhino 8 keeps crashing while performing routine operations. Lately, it seems to crash while turning layers on and off. I have updated my video card and Windows is up to date. I get crash reports which I am sending to McNeel. What follows is my system info.
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 16GB)
.NET Framework 4.8.9241.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro RTX 4000 (NVidia) Memory: 8GB, Driver date: 4-11-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.22
- Secondary monitor attached to adapter port 0
- Windows Main Display attached to adapter port 1
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPUâs maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-11-2024
Driver Version: 31.0.15.5222
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
Hey Pascal. It has happened with two different files today. This has happened in the past but when I updated Rhino, that corrected the issue. But not today. Iâm just drawing lines for a boat. There are some surfaces in the file but no shading.
Hello- if you can send us the file (tech@mcneel.com) and some idea of the steps to reproduce the crash if that is possible - you may have outlined this in the crash reports - thanks for sending those in - if so, we can work with that I think.
@majors101 - itâs possible things may work better if in Options > View > OpenGL page you un-check âGPU tessellationâ for now. Itâs better if that is on, in general, but the crashes seem to be associated, possibly, with clipping planes and we;'ve seen that sometimes helped by unchecking that setting.
I was using Orcaâs WIP for a bit and then uninstalled it. If I remember correctly, I had to add something to the .exe name. It might have been the /netfx parameter but I do not remember.
I know that I added /netfx when I started using Orca but when I checked the shortcut this morning, it wasnât there. My shortcut looked like your image.
