Latest WIP error
John
Can you bypass it i your msi?
I’m hoping that when @brian tunes up the V6 MSI installer, this problem will go away.
I keep my fingers crossed. I don’t want to change my machines yet or switch to Win 10.
I don’t think so. That bug report was specific to Windows Server 2012, and Piotr is running Windows 7.
Nope, but you’ll get used to these logs soon enough - they are the ones generated by the bootstrapper engine that we’ll be using shortly for Rhino WIP. The top says ā€œBurn v3.7.3813.0ā€ - Burn is the bootstrapper/chainer we’ll be using.
I doubt it. If the standalone installer from MS doesn’t work, it’s not going to work when embedded in our installer, either.
Well, clearly we already do! THat’s why you don’t have the correct files on your computer, and yet you are still able to try to start Rhino. But once I fix the bug, the installer will fail for you until this redistributable package is properly installed.
I recommend you contact Microsoft Support for help getting that redistributable package installed - there’s nothing we can do to help you until your computer is updated with it.
@brian
I read through the message replies.
There are several people reporting the identical symptoms in Windows 7.
That’s why I posted the link.
