I am trying to install this version of Rhino 6.
rhino_en-us_6.4.18130.19341.exe
But I keep getting this error
It always gets stuck at trying to cache vs2017 C++ redistributables(x64).
I have tried to install that redistributable before the install, but it did not skip past that prerequisite.
this is where the error start, this is from the log file
[11F8:0FDC][2018-05-21T15:05:04]i361: Created a system restore point.
[11F8:0FDC][2018-05-21T15:05:04]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{6ea3b380-7d69-400e-b345-e63b39a57ddc}, options: 0x7, disable resume: No
[11F8:0FDC][2018-05-21T15:05:04]i000: Caching bundle from: ‘C:\Users\NICHOL~1.FOG\AppData\Local\Temp{9F5B0197-89D6-456C-B4E1-4B44D35B3BF2}.be\Bootstrapper.exe’ to: ‘C:\ProgramData\Package Cache{6ea3b380-7d69-400e-b345-e63b39a57ddc}\Bootstrapper.exe’
[11F8:0FDC][2018-05-21T15:05:04]i320: Registering bundle dependency provider: {6ea3b380-7d69-400e-b345-e63b39a57ddc}, version: 6.4.18130.19341
[11F8:0FDC][2018-05-21T15:05:04]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{6ea3b380-7d69-400e-b345-e63b39a57ddc}, resume: Active, restart initiated: No, disable resume: No
[0870:16C0][2018-05-21T15:05:04]i338: Acquiring package: Redist_VC2015, payload: Redist_VC2015, copy from: D:\redist\VC2015_redist_x64.exe
[0870:16C0][2018-05-21T15:05:04]i000: Setting string variable ‘WixBundleLastUsedSource’ to value ‘D:’
[11F8:11FC][2018-05-21T15:05:04]e000: Error 0x80070490: Failed to find expected public key in certificate chain.
[11F8:11FC][2018-05-21T15:05:04]e000: Error 0x80070490: Failed to verify expected payload against actual certificate chain.
[11F8:11FC][2018-05-21T15:05:04]e000: Error 0x80070490: Failed to verify signature of payload: Redist_VC2015
[11F8:11FC][2018-05-21T15:05:04]e310: Failed to verify payload: Redist_VC2015 at path: C:\ProgramData\Package Cache.unverified\Redist_VC2015, error: 0x80070490. Deleting file.
[11F8:11FC][2018-05-21T15:05:04]e000: Error 0x80070490: Failed to cache payload: Redist_VC2015
[0870:16C0][2018-05-21T15:05:04]e314: Failed to cache payload: Redist_VC2015 from working path: C:\Users\NICHOL~1.FOG\AppData\Local\Temp{9F5B0197-89D6-456C-B4E1-4B44D35B3BF2}\Redist_VC2015, error: 0x80070490.
[0870:16C0][2018-05-21T15:05:04]e349: Application requested retry of payload: Redist_VC2015, encountered error: 0x80070490. Retrying…
[0870:16C0][2018-05-21T15:05:07]i338: Acquiring package: Redist_VC2015, payload: Redist_VC2015, copy from: D:\redist\VC2015_redist_x64.exe
[11F8:11FC][2018-05-21T15:05:07]e000: Error 0x80070490: Failed to find expected public key in certificate chain.
[11F8:11FC][2018-05-21T15:05:07]e000: Error 0x80070490: Failed to verify expected payload against actual certificate chain.
[11F8:11FC][2018-05-21T15:05:07]e000: Error 0x80070490: Failed to verify signature of payload: Redist_VC2015
[11F8:11FC][2018-05-21T15:05:07]e310: Failed to verify payload: Redist_VC2015 at path: C:\ProgramData\Package Cache.unverified\Redist_VC2015, error: 0x80070490. Deleting file.
[11F8:11FC][2018-05-21T15:05:07]e000: Error 0x80070490: Failed to cache payload: Redist_VC2015
[0870:16C0][2018-05-21T15:05:07]e314: Failed to cache payload: Redist_VC2015 from working path: C:\Users\NICHOL~1.FOG\AppData\Local\Temp{9F5B0197-89D6-456C-B4E1-4B44D35B3BF2}\Redist_VC2015, error: 0x80070490.
[0870:16C0][2018-05-21T15:05:07]e349: Application requested retry of payload: Redist_VC2015, encountered error: 0x80070490. Retrying…
[0870:16C0][2018-05-21T15:05:10]i338: Acquiring package: Redist_VC2015, payload: Redist_VC2015, copy from: D:\redist\VC2015_redist_x64.exe
[11F8:11FC][2018-05-21T15:05:10]e000: Error 0x80070490: Failed to find expected public key in certificate chain.
[11F8:11FC][2018-05-21T15:05:10]e000: Error 0x80070490: Failed to verify expected payload against actual certificate chain.
[11F8:11FC][2018-05-21T15:05:10]e000: Error 0x80070490: Failed to verify signature of payload: Redist_VC2015
[11F8:11FC][2018-05-21T15:05:10]e310: Failed to verify payload: Redist_VC2015 at path: C:\ProgramData\Package Cache.unverified\Redist_VC2015, error: 0x80070490. Deleting file.
[11F8:11FC][2018-05-21T15:05:10]e000: Error 0x80070490: Failed to cache payload: Redist_VC2015
[0870:16C0][2018-05-21T15:05:10]e314: Failed to cache payload: Redist_VC2015 from working path: C:\Users\NICHOL~1.FOG\AppData\Local\Temp{9F5B0197-89D6-456C-B4E1-4B44D35B3BF2}\Redist_VC2015, error: 0x80070490.
[0870:0C7C][2018-05-21T15:05:10]e000: Error 0x80070490: Failed while caching, aborting execution.
[11F8:0FDC][2018-05-21T15:05:10]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{6ea3b380-7d69-400e-b345-e63b39a57ddc}, resume: None, restart: None, disable resume: No
[11F8:0FDC][2018-05-21T15:05:10]i330: Removed bundle dependency provider: {6ea3b380-7d69-400e-b345-e63b39a57ddc}
[11F8:0FDC][2018-05-21T15:05:10]i352: Removing cached bundle: {6ea3b380-7d69-400e-b345-e63b39a57ddc}, from path: C:\ProgramData\Package Cache{6ea3b380-7d69-400e-b345-e63b39a57ddc}\
[11F8:0FDC][2018-05-21T15:05:10]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{6ea3b380-7d69-400e-b345-e63b39a57ddc}, resume: None, restart initiated: No, disable resume: No
[0870:17E8][2018-05-21T15:05:11]i000: >>>>>> DOWNLOAD CACHE FAILURE <<<<<<
[0870:0C7C][2018-05-21T15:05:11]i399: Apply complete, result: 0x80070490, restart: None, ba requested restart: No
[0870:17E8][2018-05-21T15:05:11]i000: GetSystemDefaultLangID() returned 1033
[0870:17E8][2018-05-21T15:05:11]i000: GetUserDefaultLangID() returned 1033
[0870:17E8][2018-05-21T15:05:11]i000: GetOsLanguage() returned en
[0870:17E8][2018-05-21T15:05:11]i000: version_NT64 = 6.1.0.0; service_pack = 1
[0870:17E8][2018-05-21T15:05:11]i000: Comparing ver_64 (6.1.0.0) to ver_win_7 (6.1.0.0)
[0870:17E8][2018-05-21T15:05:11]i000: ver_64 !< ver_win_7
[0870:17E8][2018-05-21T15:05:11]i000: Showing UI from C:\Users\NICHOL~1.FOG\AppData\Local\Temp{9F5B0197-89D6-456C-B4E1-4B44D35B3BF2}.ba\en\download_failed.htm
Any Help would be great. Does anyone know where to download the msi files for rhino 6 and all the updates it includes?
Thank you,
Nicholas
