Lasso command should work with point clouds [feature request]
Please expand the lasso command to work well also with point clouds.
Brush selection (SelBrushPoints) is very slow and you can`t precisely select points because you see dots instead of line selection.
Above you can see you it looks when I try to select points with SelBrushPoints command and one continuous stroke. I could make it lower and hide some points :slight_smile: but I can`t use the lasso selection to do that :slight_smile:
I would like to select, delete and hide points from point cloud scans. I think that many people would like to see those features inside Rhino.
Without selecting dots it`s also impossible f.e. create patch over points (patch command). In my opinion, the Lasso command should work with everything (including point clouds).
Hi Marcin -
Using the SelectionFilterVertices command, you can select points in a point cloud with the Lasso selection.
