Maybe I do something wrong, but I can’t extract points from a point cloud using the _SelBrushPoints tool. An example in the attached video.
-Simon
-Simon
Hi Simon - yeah, that seems broken, or at least not implemented, on Windows as well - though it does go through the motions, no points are extracted.
https://mcneel.myjetbrains.com/youtrack/issue/RH-52980
Hi Pascal.
Thanks for your answer. I am using as an alternative (albeit with limitations) the “_SelBrush” command that works. I’ll wait for _SelBrushPoints to be repaired. Thank you again.
-Simon
