Selection lasso which command?
V5,
wish to draw a wavering line so as to select curves within the ‘lasso’ when I end up where I started.
which command is that as I dont see anything under select tab.
Steve
@Steve1, try _Lasso :wink:
c.
Maybe _SelBrush command can be of help here.
http://docs.mcneel.com/rhino/5/help/en-us/index.htm#commands/selbrush.htm?Highlight=selbrush
-Willem
also try selboundry
Hi Clement , when I saw it said lasso points when hovered over, I passed it by as I want curves selected not just points, points being those things laid down by the points command., or when points are turned on.
thats done the trick, though click and drag and see nothing, bit quirky to use, but managed it.
Thanks guys for the other ideas
needs renaming LassoCurves, or just Lasso as is the command.
Steve
