I downloaded Lands Design latest version 5.8.2.8795 - now running in evaluation period, my company should have a licence somewhere but I cannot find it
Anyway, the problem is that Grasshopper is automatically launched everytime Rhino starts, which is rather annoying. I canāt find a way to disable that in the options and I found an old post on the forum mentionning this behaviour was supposed to be fixed since 5.4ā¦
I am testing it and having just Lands Design installed, Grasshopper only loads when I click on the Grasshopper icon. Do you have VisualARQ installed as well?
Loading looks fine. Grasshopper shouldnāt load before clicking on the Grasshopper icon. We need to check some points:
Does this happen having Lands Design disabled? You can disable Lands Design going to the āRhino Optionsā > āPlug-insā > āPlug-ins that do not ship with Rhinoā and unchecking the āEnabledā checkbox.
Do you have other Rhino plug-ins installed? Maybe one of them is causing this problem. You can check it by disabling them one at a time in the same way I explained before.
I have found something rather⦠amusing.
If I uncheck Tibidabo and recheck it, at the next restart of Rhino I donāt have any message in the command line. In this case GH does not launch.
Then at the next restart I have the message and GH starts after any command is performed in Rhino.
Iāve disabled all other 3rd parties.
Hi @magicteddy, try to disable āLands Designā and āTibidaboā plugins, as mentioned by Alfonso. Because in the video you are only unchecking āTibidaboā, and you are checking it again before closing Rhino, so nothing actually changes.
Let us know if the problem persists when Lands Design is not loaded.
Yes, I did try that already. Sorry I was unclear.
When unchecking both and starting Rhino there is no Grasshopper loading, as expected.
When both are checked, with or without 3rd parties, GH loads unexpectedly.
I tested several configurations and ended up with the behaviour shown in the video above which I find quite strange.
