Hi
I am trying to use Karamba, and all my trials were just regarding basic lines and very simple structures.
now that i started working on this complicated structure, it keeps giving me this error:
Solution exception:Could not find node at (2548.02058549423/1513.67953222763/1.03940214073738) where support number 0 is attached.
This never goes away, regardless of whatever I change in the input.
Attached is the file im working on.
Hi Khled,
you need to flatten your input for the elements and supports and there should not be any problems. If you do not flatten the input you will see that you have multiple models in your setup. It is not necessary for you to input the points in the AssembleModel.
best,
Matt
Hi I am also facing same issue. I want to assign supports at the end of the column, but when I assign support its giving error. How to resolve this ? I am new to grasshopper and Karamba. Thanking in advance
did you make sure to flatten your inputs in the AssembleModel component?
You need to make sure that the supports points are actually points in the model. The AssembleModel component also has a tolerance, where points within a certain threshold (default 0.005m) are snapped together. Please check this too
Hi, you need to convert your surface into a mesh before converting that to a shell. Otherwise Karamba3D will automatically convert your surface for you. Your points on a surface clearly do not match to the mesh vertices.
