97.02.15-2.gh (32.0 KB)
hi everyone,
I am learning to use karamba for a project and new to it, so maybe it is a simple problem but i can’t solve it.
i am trying to form a shell, there is a problem with the support points i am choosing, there is this error:
“1. Solution exception:Could not find node at (23.5886234637005/2.43707279112281/0) where support number 0 is attached.”
i checked on some other files as well but there is always this error, how can i solve this problem? i attached a part of the file.
I’m on my phone and can’t open your file now. One of these topics should be helpful:
http://www.grasshopper3d.com/m/group/discussion?id=2985220%3ATopic%3A1417847
Hi
I am trying to use Karamba, and all my trials were just regarding basic lines and very simple structures.
now that i started working on this complicated structure, it keeps giving me this error:
Solution exception:Could not find node at (2548.02058549423/1513.67953222763/1.03940214073738) where support number 0 is attached.
This never goes away, regardless of whatever I change in the input.
Attached is the file im working on.
Best regards.
shading structure karamba.gh (356.1 KB)
matttam
(Matthew Tam)
May 9, 2018, 7:47am
4
Hi @paras2.piray
Please see the example and the points below:
you need to split your lines at their intersection - The Line Line Intersection component in Karamba is very useful for this.
97.02.15-2-mt.gh (34.0 KB)
the support nodes need to be actual nodes in your structural model - therefore it gives you this error. You can use the Find Similar Member Component to snap to the points of the model
the note above also applies to point loads
best,
Matthew
