Kangaroo components not in Kangaroo2
Hi, I’m trying to follow the attached tutorial to create an inflation effect but I cannot follow since some of the components like the spring ones are not on Kangaroo2 and I don’t know how to replicate their effects.
This is the tutorial, thanks.
Just download Kangaroo Physics 0.099.
Check this K2 implementation as well.
It really does help, thank you!
I’m having a similar issue with missing components. The “Pave Random” component in Peacock 0.99.4.3 requires the three following Kangaroo components:
ZombieKangaroo
SpringsFromLine
PullToSurf
But it also says these are in Kangaroo Components v1.000. The Kangaroo project on food4rhino doesn’t have a v1.000. Where would I get these components? Since it’s a dependency for another GH plugin, it’s not something that can just be rebuilt with a different implementation.
Hi @edelmetal
I think what it needs is v0.099 which was the last release before Kangaroo 2.0
@DanielPiker thanks for the quick response–exciting to hear from the dev! Does that mean I have to uninstall Kangaroo 2, or can v0.099 and v2.0 run in GH at the same time?
No need to uninstall 2. Both can run together
YES!!! That did it. Thank you so much.
