Hi! I would like to know the equivalents of those kangaroo components in kangaroo 2.
Is there maybe a list of components of kangaroo 2 components and what they used to be in kangaroo 0.099?
Is it possible to replace them 1 to 1 or would it make more sense to just switch back to kangaroo 0.099 for this project?
What is the project? If you’re recreating something from an old tutorial I can maybe point you towards how to do it in the current version.
There’s not a direct 1:1 equivalent of all components between the versions because there was a change in the whole way it works.
The ‘Solver’ component is the main one that all Goals get fed into, similar to the ‘KangarooPhysics’ component in the old one. Settings no longer have a separate component. Load is like the old UnaryForce. ‘Trail’ is something that can now be done with the Grasshopper DataRecorder component, so it’s no longer needed.
