Hi eveyone,
Got a strange display issue here -
Lines I drew can only be seen in the perspective view, not visible in any other view…
It’s same with imported dwg lineworks…
Could anyone let me know how to fix this?
Thanks!
Li
Hmm, I assume you haven’t messed with customizing the display modes in the other viewports?
I guess the start will be to run SystemInfo in Rhino and post the results here.
Hi Helvtosaur,
Thanks so much for your response. Turned out a few things were turned off in the viewport display (curves/points…) and I had no idea there is separate viewport display setting I need to look at…
Thanks again!
Li
