Hi All,
I’m trying to use Karamba and when I use the Line to Beam elements, these are the error messages I get. Any clue on how to solve ?
Thanks
Hi All,
Thanks
Hi Reynold,
there are three versions of Karamba3D: for Rhino5, Rhino6 and Rhino7.
It seems like you installed Karamba3D for Rhino5 and try to run it with Rhino6.
Place a Karamba3D license component on the canvas and connect it to a panel:
There you see for which version of Rhino your installed Karamba3D is meant for.
In case reinstallation of the correct Karamba3D version does not help, uninstall it and manually delete all occurances of ‘karamba.gha’ from your hard disk. Then reinstall it.
Best,
Clemens
hi. I have problem with license. After I emailed to karamba3d and get the student license, I loaded the license file in license component successfully but it showed me that it is trial type and I am not able to use it for more than 20 elements. please help me
Hi, did you try closing Rhino and opening it once again to see if the license has been loaded succesfully?
Yes I have tried it. Additionally I uninstall my karamba and I downloaded it again from karamba3d’s site for my Rhino 6 and then I tried installing it and loading my license, but my license again showed the trial type
