Issue with Filtering Elements by Category and Level on Linked RVT
Is the workflow correct? Why is it empty?
No walls on the Entry Level?
I tried using this method to filter out Doors based on Levels, but I get no results… When I tried to find a Grasshopper workaround I get the doors from the 2 different links in different “Z” positions. Could this be from a bad data management? Is there a way to filter them using Rhino.Inside components?
A small example file would be helpful here. Thanks
I am still having trouble filtering Categories from linked files by level. Can anyone offer a solution?
Right now I am using a work around, but I want to be able to make it work without manually entering the Level values.
Hi Hristo,
That screenshot isn’t telling us much.
Does this help?
Re_RiR_Doors by Levels - Linked Document.gh (14.0 KB)
Hi @Japhy ,
the top part of your script is exactly what I was looking for and does the job perfectly!
Thank you very much for all the help!
Hristo
