I’m studying visualarq. I tried to make a curved&tilted curtain wall using from surface while setting up the curtain wall, but this is the result. Is there a way to make it using visualarq? Or do I have to make it myself using a grashopper? I want to make it like Frank Gary’s Dancing House!
Hi @Han-jungwoo the option to create curtain walls from surfaces might not give good results with complex surfaces. In those cases you can try to create that in Grasshopper.
In any case, if you can share your file we can investigate if the curtain wall from surfaces can work better on that geometry.
