Curved curtain wall profile
I would like to know if there is a way to create curved curtain wall profiles from curved surfaces, such as those made by splines or regular curves. I was trying to see what happens when using the vaCurtainWall > FromSurface command, but I only got good results for orthogonal profiles.
I was able to create a curved window, but not a curved curtain wall, even with a curved style enabled.
Thanks for any comment.
Hi @vin.iab curtain walls from surfaces seem to fail with these surfaces with curved boundaries. We will try tho improve this command and make it work with those kind of surfaces.
You can also use a window (from curves) instead. From the window styles dialog you can add muntins, as another way to create vertical and horizontal divisions:
Hello, Francesc.
Francesc, thank you for your answer. And, yes, I’ll do this with a window instead a curtain wall for now.
You ca also try kettyBIM Plugin, which is also a powerful tool for Modelling Curtain walls. KettyBIM | Food4Rhino
