Yes, there is a way. But you’re not giving any information on what exactly needs to be done using grasshopper and which parameters you want to control. Have you tried anything yourself? Just start by trying to create your triangle and work your way through automating the different steps described in your image. It’s usually easier to get help here if you ask about a specific problem you’re stuck with.
