I’m stuck with a code on Grasshopper. In the drawing I indicated the desired result, while in the saved Grasshopper screen there is the code I am currently setting. Basically, I’m trying to translate/rotate the pattern. I also tried connecting the pattern with “Divide Surface”, it creates points that should be manageable, but the translation/rotation doesn’t work.
[I attach image of the desired result design]
[I insert current code screenshot on Grasshopper here]
I would really appreciate it if anyone could lend me a hand or give me suggestions on how to proceed. Thanks in advance for your help!
I would like to be able to rotate the pattern… I am designing a neighborhood, the central square would be the square and the buildings are generated around the square, I would like these to be able to rotate around the square without leaving the area.
And when you provide a script you could internalize the data you want to share. Right click on curve component. So just the grasshopper script is needed.
Thank you very much! but I’m still in trouble… I should create buildings from the scheme (like attached photo), but being able to rotate everything… is it possible to combine your Grasshoper code with the creation of buildings?
