Pattern generating in GH
Hi all grasshopper master,
How would you create this 2D pattern in GH? Should I use a diamond panel in lunch box, then connect the required vertices and 4 mid points of the diamond side?
Any tips or hint would be much appreciated.
Many thanks!
You can achieve it with Polygon + Linear Array , and fyi.
HexagonalPattern.gh (9.0 KB)
Thank you Jessesn! It is interesting to see how you did it.
As I am self learning/ practicing GH, and I want to use it as a pattern generating tool.
I’m aiming to do something below as well, so I figured the green shape is basically the tile to make this pattern, but couldn’t figure out a way of tile it? or make this pattern in GH?
I suggest you first manually draw this pattern in Rhino to understand the basic logic of creating this pattern and find its basic unit, for your reference,
Then you can reproduce the parametric pattern in Grasshopper ,FYI.
PatternN.gh (18.2 KB)
