Is there anyway to construct tiles like this in grasshopper? The tricky part is to make the slightly distorted or slanted horizontal lines, but that’s what make it look interesting.
As I replied you in the previouse post, you need to identify the unit of this pattern, manually draw this unit in Rhino, and then try arraying the pattern. If possible, you can implement the same method in Grasshopper.
Try to find the unit and the pattern in Rhino, fyi.
