the quadfill and following command
and is it also possible to constraint scaling on axis ? / in other words lock axis while scaling, moving or editing ? what he does at around 09:21
Rhino 7 Help has information about commands: Rhinoceros Help
Scale1D
Scale2D
ScaleNU
ScaleByPlane
Rebuild
RebuildNU
Commands for deforming objects: Rhinoceros Help
Use Universal Deformation Technology to deform objects
Universal Deformation Technology (UDT) allows objects to be stretched, bent, and twisted. The UDT tools allow you to deform meshes, curves, surfaces, polysurfaces, and solids without worrying about the integrity of the object.
Bend
Deform objects along an arc.
Cage
Create a control cage object used by the CageEdit command to deform other objects.
CageEdit
Deform objects smoothly using control cage objects.
Flow
Re-align objects from a base curve to a target curve.
FlowAlongSrf
Re-align objects from a source surface to a target surface.
Maelstrom
Deform objects in a spiral.
ReleaseFromCage
Remove objects from a control cage.
Splop
Copy, rotate, scale, and wrap objects on a surface.
Stretch
Scale areas of an object in one direction.
Taper
Deform objects toward or away from an axis.
Twist
Deform objects by rotating portions around an axis.
It is unlikely anyone will watch a 25 minute video and then try to understand what your question is.
You may save time overall by spending time going through:
Rhino User’s Manual
Level 1 Manual
Level 2 Manual
Hey David
Thank you for answering
I didn’t want somebody to watch the whole video. I forwarded the video to the point my question occurs
