Mesh deformation
hi , I am driven by need to deform the mesh of a open hand and bring it to a close fist position
i was thinking about using flow along surface as a deformation cage. Mi idea was to model the deformed surface by using quad remesh/SubD gumball functionality and then flow the mesh along the subD surface basically as shown below
problem is that flow along surface does not accept SubD object and polisrurfaces either .
any suggestion on possible solutions inside rhino? would the command flow along subd make sense ? thanks
Check out this topic
Skeleton fattener + mesh cage morph - Grasshopper - McNeel Forum
A few more threads with examples using the tool Martin linked above:
thanks a lot Daniel
mesh cage morph component fullfilled my needs :wink:
