Me version of Iris expired even with using the latest version Iris 0.6.3.0 for Rhino Windows v6
Is tehre any newer version?
Installers have been updated. Please check food4rhino. Thanks for reporting!
Thank you for the new version.
I tried using it, but I got an error message saying “Plug-in file writing failed”.
What is wrong?
Does it fail for any kind of object?
The same phenomenon occurs even if tried with simple shape.
By the way, the version of Rhino is 6 sr9 latest.
Are you trying to save in the .html format? If so, I’ve detected an error. I’ll fix it shortly.
I am trying to save in .html format.
Thank you for correction.
Installers have been updated. Please check and let me know if the problem persists.
Thanks!
I fixed it.
thank you very much.
@fraguada, I tried Yak to update Iris on my system. After a restart, I get an “Error loading” message - “application initialization failed”. Yak tells me that the installed version is 0.6.1 - 2018-03-14.
Should it work to use the package manager to update Iris?
Yes it works, but I’ve not added Iris recently to yak (as you can see from the date). In the future, this will be an automated process, but for now it is a manual one that I need to get into the habit of doing.
@wim Posting this publicly in case it helps anyone else…
Unfortunately if you’ve previously installed Iris manually (i.e. without the package manager) then you might run into issues. Try first manually uninstalling the previous version:
- Delete the key from the registry:
HKEY_CURRENT_USER\Software\McNeel\Rhinoceros\6.0\Plug-Ins\1cd9c8f5-c901-426c-8e80-d6a2e2b18bba
- Delete the folder from the plug-ins directory:
%AppData%\McNeel\Rhinoceros\6.0\Plug-ins\Iris (1cd9c8f5-c901-426c-8e80-d6a2e2b18bba)
Thanks, @will,
That did the trick here.
Hmmm….
@will, I spoke too soon.
I was able to export a simple box to html, then closed Rhino and started again. And now I’m getting those Error loading - Iris.WinR6.rhp
messages again…
Ah, yes. I’m seeing the same thing.
I think it’s happening because the 0.6.2 package includes both the Rhino 5 and Rhino 6 RHP files.
@fraguada Rhino currently tries to load any RHP that it finds in a package. Could you try releasing a new version of the package with only the Rhino 6 RHP? The 0.6.2 version can be hidden with yak yank iris 0.6.2
Ok. I yanked 0.6.2 and pushed 0.6.3 with only the R6 rhp. My apologies for keeping the R5 stuff in there!
Thanks Luis!
I used the Update button in Yak to update to 0.6.3.
After a Rhino restart, everything seems to work fine!
Unable to load Iris.WinR6.rhp plug-in application initialization failed.
I got this error after updating the expired plug-in.
Hi Marcus - you will have to wait for an updated version to be available.
Okay!
