I have an loading error with:
- Iris 0.6.1.0 for Rhino Windows (v5 and v6)
- And Rhino 6 SR7 (6.7.18190.21071, 09/07/2018)
Also I would like to disable it but I do not find it in the list of modules
jmv.
jmv.
I’m away until July 17th. Will respond when I return.
Nothing new here with this sort of behavior of the IRIS plugin.
@kitjmv I just cleared out any installations of Iris, installed Rhino for Windows 6, sr7, downloaded Iris from Food4Rhino, installed Iris through the Rhino Install Engine by double clicking the downloaded file (iriswin.rhi), and opened Rhino 6 sr7 and Iris loaded fine.
Is this how you installed Iris? Take a look at your installed plugins in C:\Users\<username>\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\
. Is there a folder for Iris?
What is up with IRIS. It won’t work for me but it won’t go away either! It pops up a window every time I open R6 despite disabling it as a plug in and even deleting its folder in the plugins folder for R6.
Hi,Iris is expired. I can not find the newer version.
Iris has been updated. Installers on f4r and on yak.
Luis, I have done the time extension a couple of times since your last report here and again right this moment from Food 4 Rhino and it appears to install fine for 5,6 and 7. I opened a new instance of 6 and tried an export and chose your html Iris export and I get a message that there is no plugin. Please either provide a workable download.
