Error when exporting
Hy all,
When i try to export an object i hit this error
Preparing WebGL files for viewing locally
Error writing file C:\Users\junior\Desktop\0.iris
Error saving file C:\Users\junior\Desktop\0.iris
Can someone give me some tips
What is your os? Which version of rhino? What’s in your rhino model?
Thanks,
Luis
Windows 7 64 bit OS ,
Version 5 SR13 64-bit
(5.13.60523.20140, 5/23/2016)
When i try to export a cube for example or any other object i encounter this error.
Thank you. I believe it is an issue with the os version and the way I’ve compiled the plugin…You are the second person who is showing this error who is on win 7. It is a known issue for this last version. I hope to have more information regarding this issue next week.
Thank you for your fast reply.
Maybe i will try to change my OS this weekend but not sure i have the time. If not i hope there will be a solution for this as soon as possible.
@Bogdan_Batranu @wim I was able to test this weekend on a windows 7 x64 machine and was not able to duplicate these error. I downloaded the Iris 0.5.2 for Rhino 5 Windows, double clicked to install, and started Rhino 5 (sr12 in my case), exported a couple of boxes, no problem. I did the same again, but this time I went to my plugins folder and deleted Iris, and reinstalled the latest rhi. Same thing, install worked fine.
@Bogdan_Batranu do you have Rhino WIP for Windows Installed? Would you be willing to try Iris there?
Best,
Luis
Hello Mr. Fraguada,
I uninstall the plugin and now i installed it again and it seems that is working fine now.
I installed also Rhino WIP and it is working just fine, now in both version of the program.
I want to thank you for your support and work done.
