iRhino3D WIP is now available via Testflight
Testflight is what we use to provide WIP versions of iRhino with new features that are being worked on before they are introduced into the official iRhino app.
WIP releases of iRhino3D via Testflight contain some features that are not completely finished. For a stable release download iRhino3D from the AppStore.
iRhino3D WIP (9.0.25042 (10020.1) - February 11, 2025) is now available via Testflight
Bugs Fixed:
  • Inspect: AnnotateSelected not allow moving control points (RV-1329)
  • No subsystem:
    • Command options popover too small (RV-1339)
    • Enable / Disable clipping planes (RV-1338)
    • Markup: auto smoothing not good (RV-1317)
    • Markup cplane on camera target (RV-1326)
    • AR mode lock should lock reset buttons (RV-1343)
    • Navigation slow in model with markup (RV-1316)
  • Scan: Texture mapping saved by object scan not Rhino7 friendly (RV-1334)
  • UI: User interface tour popovers hidden (RV-1340)
Enhancements:
  • UI: TestedAnnotateSelected command shows an enable/disable toggle dot on selected clipping plane (RV-766)
  • Display: Added "Use Max Metal Samples" setting to Appstore build (RV-1341)
Features Added:
  • IR.Touch: Added TestAnnotateSelected command to display lengths of linear segments on selected polyline and polysurfaces (RV-54)
iRhino3D WIP (9.0.25120 (11030.1) - April 30, 2025) is now available via Testflight
Bugs Fixed:
  • Command-line: Command options popover too small (RV-1339)
  • Markup:
    • Unable to start a markup (RV-1364)
    • Not using camera plane (RV-1365)
    • Draw behind objects (RV-1358)
    • Moved Markup plane to camera target (RV-1326)
  • No subsystem:
    • Voice accessibility of main menu (RV-1382)
    • PrintDisplay in iRhino (RV-838)
    • Compute/Hops in iRhino (RV-1360)
  • Scan:
    • Room scan floor plate reports area double the actual (RV-1331)
    • Texture mapping saved by object scan not Rhino7 friendly (RV-1334)
  • UI:
    • Drawing aids popover heights too small (RV-1374)
    • Use Rhino 9 icons in iRhino (RV-1349)
    • User interface tour popovers hidden (RV-1340)
Enhancements:
  • Inspect: Display object attribute user text for selected objects (RV-1353)
  • Markup: Draws polyline strokes by default (RV-1317)
  • Settings: Added "Selected object(s) helpers" option (Settings > General) (RV-1338)
Features Added:
  • AR: Selfie mode allows capturing face geometry (RV-1371)
Usability Problems Fixed:
  • Settings: Added "Named views set clipping planes" (General > View) (RV-1350)
iRhino3D WIP (9.0.25174 (15270.1) - June 23, 2025) is now available via Testflight
Bugs Fixed:
  • Display:
    • Shaded/Rendered do not work on iPhone XS (RV-1376)
    • Added “Use Max Metal Samples” setting to Appstore build (RV-1341)
  • Markup:
  • No subsystem:
    • Command suggestions when there’s space (RV-1243)
  • Scan:
  • UI:
Crashes Fixed:
  • Inspect: Crashes iRhino (RV-1386)
Enhancements:
  • RH-82788 Linetype: Thick polyline breaks between adjacent segments with small angles
Features Added:
iRhino3D WIP (9.0.25262 (11020.1) - Sept 19, 2025) is now available via Testflight
Bugs Fixed:
  • Markup:
    • Markup mode is broken (RV-1402)
    • What is selected is not what gets drawn (RV-1384)
    • Gumball drag changes view (RV-1414)
    • Cursor hover is laggy (RV-1413)
Features Added:
  • Object Scan: Output PointCloud to a hidden layer (RV-1262)
  • Change object layer (RV-1387)
  • Pose detection in iRhino (RV-1403)
iRhino3D WIP (9.0.26012 (10030.1) - January 12, 2026) is now available via Testflight
Big Changes
  • Resizable navigation panel. This allows having a side by side view even on iPhone
  • Finger gesture orbit lock allows orbiting without accidentally selecting and dragging objects.
Bugs Fixed:
  • Display:
  • Gumball: Dragging Gumball handle orbits view (RV-1414)
  • Markup:
    • Previous markups don’t hide in iRhino (RV-1394)
  • No subsystem:
    • Sidebar navigation on landscape iPhone (RV-1439)
    • Accidentally dragging (RV-1437)
    • Shift gets stuck (RV-1436)
    • Refactor keyboard shortcuts (RV-1438)
    • Build iRhino for iOS 26 (RV-1426)
  • Scan:
  • Trackpad: Cursor hover is laggy (RV-1413)
  • UI:
    • Update “Guides” to open new website (RV-1425)
Crashes Fixed:
Enhancements:
  • Layer: Allows changing object's layer (RV-1387)
  • UI:
    • Improved feedback experience (RV-1237)
    • TestedAnnotateSelected command shows an enable/disable toggle dot on selected clipping plane (RV-766)
Features Added:
  • AR:
    • Added “Body” mode for pose detection (RV-1403)
    • Selfie mode allows capturing face geometry (RV-1371)
  • Display: Added Print Display (RV-838)
iRhino3D WIP ( 9.0.26120 (12510.1) - April 30, 2026) is now available via Testflight
Bugs Fixed:
  • Analysis: Distance measurement incorrectly starts from current cursor position (RV-1429)
  • Gesture:
    • single swipe should pan orthographic view (RV-1468)
    • Removed “Continuous Draw” option from Settings (RV-1454)
  • Markup:
    • Markup colorpicker on iOS bug (RV-1463)
    • Initial position for new text is off-screen (RV-1461)
    • Button height reduced when WIP features are turned off (RV-1458)
    • Tapping color swatch locks up whole app (RV-1459)
    • New HUD missing Text button (RV-1457)
  • No subsystem:
    • iRhino drag panel indicator (RV-1465)
    • Running every markup tool brings up the keyboard (RV-1470)
    • Text in markup uses command suggestion (RV-1469)
    • Drag is broken (RV-1448)
    • Getpoint on white background (RV-1455)
  • UI: Main Menu panel doesn't open after showing markup panel (RV-1443)
Enhancements:
  • Object Snap: Added "Disable OSnaps" to object snap popup menu (RV-1433)
Regressions Fixed:
  • roomplan: Roomscan can't be used on iPhone (RV-1442)
