Hi everybody, McNeel developers.
I’m making this thread to not forget about my common problems while using Rhino.
Note that, I’m not using WIP, but here and then I check if whatwassupposedtobeon7 is fixed on wip.
Usually not. What was marked for “7.x” was later changed to “8.x” (like a stab in the back, but I love you guys anyway. Rhino fan here!)
So, I hope on 8.x you will fix some of the things that bugs me, and I’m already begging you to not push them to 9.x!
(Did I just gave up all my hopes to see 7 fixed? …
Let’s make a list?
SubD, which I’m using daily:
– Curvature analysis? I’m using some 100-row code with GH to patch the absence of official support, but it’s still bothering to have to reference a SubD, open/close GH to see the coloured scale. We have no SubD curvature analysis on 7, but not even on WIP! Is it planned?
– 2 years later > SubD bevels feedback - #8 by BrianJ
– I have so much ideas for SubD (mainly to boost my workflow). I tried to do things by myself with c# but the underlying structure of the class is broken! Subd.Vertices only have a .First and .Next , no topology, too few methods, too little depth. Vertex and Edge tags get scrambled up at any edit!
– Add a optional value somwehere for which the double-click on edges or faces will not chain-select indefinitely, but only x amount every time. -
C# scripts on Grasshopper on WIP: the editor got problems. Maybe related to Eto?
Repeatable: Rhino fullscreen on monitor 1, GH fullscreen on monitor 2. Create a c# script component, double click to edit the code. The editor pops and I was too fast to drag it from screen 2 to screen 1. Rhino UI totally dead . After a mix of random keystrokes I managed to minimize Rhino and maximise it again, unstuck.
The c# editor now opens and “sort itself” in a couple of seconds (that must be a really unoptimized step), if you drag that window cross-screen before it finish > total UI death.
(both screens have same windows scale %)
Can I ask already for older c# editor on V8? Is it possible?
WIP UI is ugly. Bloated. Inflated. Lot of lost space due to large borders everywhere, double borders. Popup window by clicking the wheel is now useless.
Small windows (like Zebra analysis or Curvature graph) are almost un-resizeable because the handle appears only at 1 pixel. -
3d connexion mouse on WIP stutters more. Sometime it even randomly completely stops to work for a second or two.
I’m not using blocks, mainly because I were so “burned” on Rhino 4 age that I’m forever scared to try them again. Please listen other users about blocks. I can’t comment about this.
Thanks for everything.
Sorry for the textwall…
