Imported shaded files are displaying only selected layer colors, but most colors are defaulting to gray. Without the shaded colors for each layer the models look flat and unimpressive. Help please!
Hrmmm. Did you apply materials to each of the objects and set their Diffuse color? If you upload the 3dm file, I can take a look and see if I can figure out what is going wrong.
(There is still a bug with the Color By Layer logic that needs fixing…so if you are trying to that, you’ll have to use the Object’s material color instead).
Good to know about the color by layer issue. Render materials are assigned to each object, so it maybe a defuse color or other setting I’m missing. I’ll send you a file to review.
