Essentially when I’m working in shaded view all objects are a dark gray despite the layer colors being different. The only relation to layer color is an outline around the object. I don’t recall having this problem not too long ago. I’ve tried tampering with the settings and resetting the shaded view settings back to default but to no avail. Running Rhino 5 on Windows 7.
I’ve attached screen shots comparing shaded and ghosted views. Seems to work fine in ghosted. Also excuse the terrible graphics card on my laptop. On that note, I don’t have this problem on my desktop (iMac running Windows 7).
Would appreciate anyone shedding some light on the problem. It’d make working on my laptop much more convenient!
Hi Anthony- my first guess is the shaded display mode has been tweaked - if you open Options > View > Display modes, is the Shaded mode shown in blue text? If so, any specific settings that are blue are non-default, most likely ‘Color & Material usage’. One quick test would be to click on ‘Restore defaults’.
Hi Pascal, nothing was in blue no and it seemed like it was actually set to default. However under the ‘default’ settings Color & Material usage was set to ‘Custom Material for all objects’. I’ve changed it to ‘Object’s Color’ and all seems to be working fine, so thank you for bringing this setting to my attention.
Default Shaded mode does not reflect color from the color picker, even when working with ‘Flat shading’ and in 2D.
To get a good reproduction of the colors, I use indeed
Color & Material usage = Object’s Color
Gloss = 1
I know this is an old post but I encountered this problem as well.
For anyone else that has issues with this example.
Try this command:
RemovePerFaceColors and experience your unnecessary stress levels go down instantly.
