How to add textures? Render view only siplays objects in gray
Trying to figure out how this app works. I can’t seem to get the rendered view to show the colors I’ve applied to objects. They show up in a shaded view but not in render view.
I see now that textures are just supported you can’t add them to the model.
I’m guessing that you probably can’t move objects to different layers. That would be something you need to do back at your computer I imagine.
Not a lot of info available on how to use the app at least as far as I have found. If anyone knows of any additional resources please let me know.
Thank you
That’s correct, iRhino will display textures if your model has them but there are no tools in iRHino to apply textures to a model.
iRhino is still a viewer, we’re adding some modeling capabilities but we have a long way to go and for now we’re not looking at adding a material editor.
I logged this request. I should be able to get it into the next build: RV-1387 Change object layer
This is now fixed in latest iRhino build:
