Buongiorno a tutti, Vi sottopongo il mio problema… Rhino 7 si chiude cercando di utilizzare il comando “procedura guidata riparazione di mesh”. Funziona solo se utilizzo le primitive mesh. Ho provato, convertendo una sfera da superficie in mesh, attivo il comando di riparazione compare la finestra di dialogo e poi il programma si chiude. Forse sbaglio io qualcosa.
Grazie in anticipo
Uncle Google says:
“Hello everyone, I submit my problem … Rhino 7 closes trying to use the “mesh repair wizard” command. It only works if I use mesh primitives. I tried, converting a sphere from surface to mesh, activating the repair command the dialog box appears and then the program closes. Maybe I’m doing something wrong.
Thanks in advance”
Hello - please run the _SystemInfo command in Rhino and Copy/Paste the results here.
Rhino 7 SR6 2021-5-7 (Rhino 7, 7.6.21127.19001, Git hash:master @ aec74c050f3ca28ab3cfd6882e9453a52366a9b7)
License type: Commerciale, build 2021-05-07
License details: Cloud Zoo
Windows 10.0.19041 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [82% battery remaining]
Primary display: Intel(R) HD Graphics 530 (Intel) Memory: 1GB, Driver date: 11-11-2016 (M-D-Y).
Integrated graphics device with 3 adapter port(s)
Primary OpenGL: NVIDIA GeForce GTX 950M (NVidia) Memory: 4GB, Driver date: 12-4-2017 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 388.57
Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-4-2017
Driver Version: 23.21.13.8857
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.6.21127.19001
Hello - the first thing is to get the most recent drivers for the video chips from the Intel website for the Intel(R) HD Graphics 530 and the NVidia website for the NVIDIA GeForce GTX 950M
Buonasera Pascal, ti ringrazio molto per le risposte.
Ho fatto gli aggiornamenti della scheda video che mi hai consigliato, ma il problema rimane e provando più volte ho riscontrato che il programma si chiude quando si trasformano le superfici in mesh usando, dal menu “opzioni mesh poligonali” e solo controlli semplici.
Ti ringrazio ancora per l’aiuto.
@giuseppe - if you have a moment, can you please see if we can get a reproducible case from Ale?
thanks,
Salve Ale,
Vorrei aiutarti nella soluzione del problema.
Ti chiederei di inoltrare nuovamente il SystemInfo di Rhino dono gli aggiornamenti della scheda video. Sia integrata che dedicata. Dobbiamo fare in modo che Il sistema operativo renda disponibile la scheda dedicata GTX come primaria.
Nel forum italiano abbiamo un post dedicato a questo argomento. nel caso:
Buongiorno Giuseppe,
ecco le info che mi hai chiesto…NVIDIA aggiornata, ma Intel(R) HD Graphics 530 mi da un messaggio di errore.
Ho dato un’occhiata al forum e mi sembra corretta l’impostazione …credo ! ( ti allego immagine).
Grazie per la disponibilità.
Alessandra
Primary OpenGL: NVIDIA GeForce GTX 950M (NVidia) Memory: 4GB, Driver date: 4-23-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 466.27
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 4-23-2021
Driver Version: 27.21.14.6627
Ale ciao, ho spostato sul forum italiano perché questo è solo inglese. Proseguiamo li.
