Ho Rhino 7 e mi si è crushato. sostanzialmente non funziona più il passaggio tra le viste in sub D . cioè da linee morbide a linee spigolose.
e sto cercando di capire come risolvere il problema. anche perchè ha già fatto tre emergency save e al terzo, il programma non funziona con tutte le opzioni di prima.
e ciò mi fa imbestialire anche perchè l’ho pagato per motivi di lavoro e studio.
ringrazio chiunque mi possa suggerire come risolvere il problema.
First step is to make sure you have the most recent video drivers
si il mio computer è un concept d 5 , e l’ho comprato apposta perchè supportasse tutto quanto. perciò non capisco come mai mi combina ste cose.
Run _Systeminfo in Rhino and post the result here
i also realized now, when tring to renderise that it doesn’t rendrer. no more.
i got a good computer and a good program. but unluckly i got this bloody problem. i need that to work.
ok. i’ll try
ecco le informazioni.
Rhino 7 SR2 2021-1-21 (Rhino 7, 7.2.21021.07001, Git hash:master @ 96ff97351fbdf5d2acdeaf781aea1577f2ff60f7)
License type: Educational, build 2021-01-21
License details: Cloud Zoo
Windows 10.0.18363 SR0.0 or greater (Physical RAM: 16Gb)
Secondary graphics devices.
NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 9-4-2019 (M-D-Y).
> Integrated acclerated graphics device (shares primary device ports)
- This device is not being used
Intel® UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 5-28-2019 (M-D-Y).
> Integrated graphics device with 0 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
ATTENTION:
No graphics device is being used. Either an error occurred on startup, or certain devices have been disabled.
See below for any possible configuration changes that may help resolve this issue.
- Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Non supportato
Driver Date: 5-28-2019
Driver Version: 26.20.100.6911
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.2.21021.7001
There you have it. Your drivers are from 2019!
Update those and your problems most likely vanish.
thanks for your time.
one more thing, just because i’m new with rhino and in particular with the seventh.
how can i update those things or that thing? where i start from?
Devi aggiornare i driver grafici da windows. Vai sul sito nvidia e cerca driver per la tua scheda rtx 2060.
Gd
Download drivers from Nvidia.com for your rtx 2060 and perform a clean install
grazie mille. thanks a lot. !!!
And here for your intel:
ok. thanks
