Rhino.inside for Revit 2026
I am not able to get my rhino.inside plugin to work for Revit 2026. I have tried uninstalling and reinstalling the plugin because I originally had it for previous versions of Revit, and I installed 2026 after I had already installed rhino.inside.
Now after the reinstall -
First time I opened Revit 2026 it froze my entire laptop to the point I had to hard reset.
Then after restarting the laptop a second time Revit worked but the plugin still does not show up at all.
My revit 2024 version works just fine and allows me to choose between rhino 7 or rhino 8 when it opens.
Any troubleshooting help would be appreciated
Hi Craig, Ensure you are on the latest version of Rhino.
Thanks. I think actually the problem might be that I have Rhino.inside v1.26 (I.T. bottlenecks what is available to us on a software deployment platform). I see that it might be an issue that v1.26 does not support Revit 2026, and so I’m asking for I.T. to make the latest stable build available. I’m not sure it will fix the issue but it’s probably a good starting point.
Yeah, you’ll need 1.32 or above.
