I’m trying to create a triangular tensile structure in kangaroo, but I’m not able to tighten the mesh to make it look firm, It either gets sucked in too much and thins the base mesh too much, or sags, and looks like it’s crumpling. I’m using the edge lengths function to control the mesh size. I’m not sure how to upload files here, but can readily upload the file if there is a possibility.
Yes, we’ll need to see the files to help.
When replying you can use this icon to add a file
Thanks, missed that, uploading it here
rhino tensile triangular.3dm (89.5 KB)
tensile roof.gh (21.1 KB)
If you notice, the edges either sag or get pulled in too tightly when the length factor function is modified. Still very new to gh and kangaroo, so really trying to find my way around it.
Attaching some reference images of what I’m trying to acheive
Thanks in advance
You need to give the exterior edges of the mesh a higher tension than the interior.
It is also often helpful to remesh before relaxing so the edges are more evenly distributed.
tensile_edgecables.gh (11.7 KB)
This is such a big help. Thank you so much. Followed a lot of tutorials that prdominantly showed using the edgelength function. Didn’t know about the line function up until now. Also in addition, would you be able to tell me how i could go about causing a slight depression in the centre, so it sorta looks like the images? I’m assuming its got to be a load function, but i’m not sure which one or how to use it.
Got it!! Works like a charm. Thank you so much!
Hey a lot of time in between but would you say that by applying the ‘VertexLoads’ goal, it can be used to create meshes that experience ONLY tension forces? Or are there more goals involved for that
When you set the rest lengths of the edges to zero, it results in meshes which are only in tension.
Sorry but you mean the LengthFactor of ‘EdgeLength’ or what exactly you mean with rest length ![]()
Yes, set the ‘LengthFactor’ input to zero if using the EdgeLengths component
Ah, okay perfect thank you! Trying to get into real Kangaroo form finding but its very hard to find valuable resources outside plain yt tutorials so thats a big help! Appreciate your time ![]()
