In Rhino 8 the default "Final Quality" render is now set at 1500 samples
In Rhino 8 the default “Final Quality” render is now set at 1500 samples. I believe this is an increase in samples from Rhino 7 [1000 samples]. If so, why please the increase?
[I tried searching the Forum.]
Thank you,
Andy
Final quality has been 1500 samples since 2019.
Raytraced default setting is 1000 samples. Maybe that is what you mixed up?
(proof: Introduce preset settings for render quality. · mcneel/RhinoCycles@7f226ad · GitHub )
Hello Nathan,
Yes mixed up. And simply mistaken. I had taken the “Final Quality” setting for a render with in a view port not an image render. The word “session” escaped my reading / reading comprehension. For Rhino 8 now even I can comprehend because you have kindly programed in the “Quality” dialog drop down the number of samples.
Probably apparent that a rendered image is not a workflow I am at all familiar.
Thank you for the help and clarification. Much appreciated,
Andy
