I would like the quality of my render to be better than ‘good’ but it doesn’t need to be as good as ‘final’ as I don’t have the time for those.
Can I set the quality to good and increase it’s results slightly by tuning anything in the “Rhino Render Advanced Settings”?
Are you using denoisers? If so, crank up the settings to whatever you want (final) and then bail out when the image is good enough for your needs.
if not grab the intel or nvidia denoisers from package manager.
then load them from the post effects panel when you run a render or raytraced display (which only shows when you run raytraced model or a render)
You can override the sample count in the session section of the Rhino Render Advanced Settings. Don’t forget to check also Override Production Render Quality.
