Often, when I open/import DWG files into Rhino I have issues with shifted/overlapping text fragments. Changing alignment is not the answer because it helps to remove overlapping only sometimes, and at the same time, it moves texts in the wrong place.
Is there any automatic solution for that or will be at one point? Or this is a thing about DWG’s that always will be problematic?
Rhino text objects have 9 different possibilities for placement - any combination of Left, Center, Right horizontal justification and Top, Middle, Bottom vertical justification. These are all relative to the text insertion point. I’m willing to bet that what doesn’t transfer correctly is the justification information, the other influencing factor could be the type size/font. The insertion points are probably correct.
It looks like the labels in the originals are in fact two different text objects. You might just look at a typical pair of those in the original program and compare size, justification and insertion points to those in Rhino.
