Import SketchUp file WITHOUT meshes?
Hi. I’m looking for a good workflow from SketchUp to Rhino. However, it appears that every import/export option gives me a triangulated mesh in Rhino.
Is there any way to get the model into a proper Rhino format?
Any help would be appreciated, thank you.
Either you can run MeshToNurb on the imported mesh, or, normally, with the Sketchup to Rhino importer, you have the option to create Rhino surfaces on import insead of meshes.
One way or the other, once you have polysurfaces, I would then run MergeAllFaces on the them- do this in small batches if there are many objects.
–Mitch
Thanks, that did it. The only wired thing is that the display color defaults to black (white in 3d view) so I have to set everything back to “by Layer” after import.
