- I would like to know if I can hide the layers except the inner retaining wall except for the window opening hole if I have 3 layers when I draw the wall and the outer wall is the middle of the finish is the inner retaining wall.
- I would like to know if it is possible to work on it by drawing with the inner retaining wall layer and writing only the outer finish separately.
- In general, it is because the external finish is separately worked with retaining wall concrete after construction.
(To use a wall frame.)
Hi @user2166
In the wall styles dialog (vaWallStyles), you can edit a wall style, and assign each one of its layers to a Rhino layer, from the attributes tab, (or set its visibility to Hidden directly):
Then you can control the wall layer visibility by turning on or off the layers where they are located, from the Rhino Layer manager:
